Sep 5, 2025 5:03 AM UTC
stm32wb55rev6: How to send data from server to client using usart1?
Hey,
I am using the stm32wb55rev6 boards as the client and server to send and receive the data.
i am able to establish the connection between the server and the client.
How can i be able to send the data from the server to the client using the usart1.Do i need to create a new  task in the sequencer using the util _regtask or is there any document related to that?
STTwo-32
STTwo-32Best answer
Sep 5, 2025 3:42 PM UTC
Hello @TejasK
For such implementation. I suggest you follow the implementation of the BLE_CableReplacement that send data from a COM port throw UART1 to a node and print it on the other (client and server). To understand how it works, you can use the readme.txt file of the example.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Hello @TejasK
Best Regards.
STTwo-32
TejasKAuthor
Sep 6, 2025 8:44 AM UTC
can u expalin m in detail what changes should i do?because i am bit confused in this trransmit and receive.
