VBuse
Oct 15, 2019 5:50 PM UTC
STM32WB55CG is under read/write protection in STM32CubeProgrammer_CLI and no protection in STM32CubeProgrammer.
In STM32CubeProgrammer I can set RDP on AA level and BB level, but in CLI mode read/write protection is constantly in BB. In CLI protection byte doesnt change, I mean I can't change it
and can't write FUS or stack, and even check the fuse version.
C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\bin>STM32_Programmer_CLI.exe -c port=usb1 -rdu
                      STM32CubeProgrammer v2.1.0
USB speed  : Full Speed (12MBit/s)
Manuf. ID  : STMicroelectronics
Product ID : DFU in FS Mode
SN         : 207D308E3036
FW version : 0x011a
Device ID  : unknown
Warning: Device is under Read Out Protection
Disabling memory Read Protection...
Memory Read Protection disabled successfully
SN         : 207D308E3036
FW version : 0x011a
Device ID  : unknown
VBuse
VBuseAuthor
Oct 15, 2019 5:54 PM UTC
More action
C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\bin>STM32_Programmer_CLI.exe -c port=usb1 -r32 0x20030030 1
SN         : 207D308E3036
FW version : 0x011a
Device ID  : unknown
Error: RDP level is set to 1 (0xBB), try using Read UnProtect (-rdu) command in order to remove the Read Out Protection.
C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\bin>STM32_Programmer_CLI.exe -c port=usb1 -fwdelete
SN         : 207D308E3036
FW version : 0x011a
Device ID  : unknown
Error: fwdelete command is not supported for such device
