SWenn.1
Senior III
Apr 29, 2023 2:31 PM UTC
STM32WB55 User Manual RCC register is missing bit 18????
I am trying to incorporate the X-Cube-EEPROM package into an existing STM32WB55 Nucleo design that I have. In the process one of the compile errors refers to an RCC bit:
'RCC_CR_HSEBYP' undeclared (first use in this function); did you mean 'RCC_BDCR_LSEBYP'?
Your stm32wbxx.h file within the CMSIS/Device/ST/STM32WBxx/Include folder calls out the RCC_CR_HSEBYP as bit 18.
This bit doesn't even exist in the manual....What kind of code is this???
This is VERY subpar.
KDJEM.1
KDJEM.1Best answer
May 2, 2023 9:08 AM UTC
Hello @SWenn.1​ ,
In which version of the STM32CubeWB repository did you find the RCC_CR_HSEBYP bit in the CMSIS files?
This bits is removed in the CMSIS files from STM32CubeWB V 1.7.0 version.
For that please refer to the STM32CubeWB last version.
Kaouthar
KDJEM.1
KDJEM.1Best answer
Hello @SWenn.1​ ,
Kaouthar
SWenn.1
SWenn.1Author
Senior III
May 2, 2023 12:27 PM UTC
Hello Kaouthar....
Thank you for the response. I was using a github repo example for flash erasing/writing for persistent variables and the application called for use of the bit. I downloaded the application and married it to STM32CubeWB V1.7.0. At compile time it errored out as V1.7.0 does not recognize the bit field. I have worked my way around this.
Thanks again.
