~Amit~
Jan 29, 2020 9:04 PM UTC
STM32WB55 p2p_router & freeRTOS issue
I am trying to initiate a code via cubeMx for the STM32WB55.
I want to add freeRTOS together with a p2p_router capability but facing an issue that the both above not supported simultansly.
Any special reason for that?
Is there a way to achieve that?
Thanks.
Remi QUINTIN
Jan 31, 2020 10:38 AM UTC
I managed to reproduce your issue.
​Unfortunately, the // support of many applications with free RTOS via CubeMX is under development as we target to support many other real time OS.
Meanwhile I would advise you to look at the project
STM32Cube_FW_WB_V1.4.0\STM32Cube_FW_WB_V1.4.0\Projects\P-NUCLEO-WB55.Nucleo\Applications\BLE\BLE_HeartRateFreeRTOS
and use it as a reference to port the p2pRouter application on FreeRTOS.
~Amit~
~Amit~Author
Jan 31, 2020 9:42 PM UTC
Yeah I took that as last option, I hoped to find a better way than merge 2 demos cause than my cube file and source code are not consistent...
Thanks.
