[STM32WB55] How to use CHAR_PROP_WRITE modified in sample code
Hi Sir,
I use sample code in STM32Cube_FW_WB_V1.13.0\Projects\P-NUCLEO-WB55.Nucleo\Applications\BLE\BLE_p2pServer and BLE_p2pClient. The BLE characteristic's property CHAR_PROP_WRITE_WITHOUT_RESP is used in the sample, I try to modified it as CHAR_PROP_WRITE, then client cannot control blue LED by pressing SW1 button. is there anywhere need to modify if I use CHAR_PROP_WRITE property? thank you.
Best regards,
C
