metal2oxide
Aug 6, 2021 11:52 AM UTC
STM32WB55 CPU2 flash size
How much flash memory is allocated for CPU2 flash and is it possible to write a RF firmware without involvement of CPU2
Aug 6, 2021 2:06 PM UTC
CPU2 is not designed to run user code. It is allocated the second half of the flash by default, although this is adjustable.
BSANT.17
Aug 6, 2021 2:23 PM UTC
Allocation depends on RF stack you choose. You can find RF firmware size on %HOMEPATH%\STM32Cube\Repository\STM32Cube_FW_WB_V1.12.1\Projects\STM32WB_Copro_Wireless_Binaries\STM32WB5x\
I think you can't use RF with CPU1 only.
metal2oxide
Aug 9, 2021 8:52 AM UTC
what is the minium allocation which needs to be done for second core. I want CPU1 core to use the max flash
