STM32WB05KZ ACI_GATT_SRV_READ_VSEVT_CODE doesn't get triggered
I've been unable to get the ACI_GATT_SRV_READ_VSEVT_CODE case to trigger on the STM32WB05. Since this chip doesn't seem to support line for line debugging with an STLink to the Serial Wire interface due to Sequencer, I haven't been able to find a solution. The ACI_GATT_SRV_WRITE_VSEVT_CODE triggers fine and I've enabled GATT_NOTIFY_READ_REQ_AND_WAIT_FOR_APPL_RESP in CUBEMX. Does anyone know what the issue could be?
Kind Regards
