STM32WB tBleStatus values
This is my architecture:
- 1 board client.
- 5 board servers.
In the client i have:
- A routine that try to connect, pair and update MTU size of all the servers.
- A routine that send and receive message from the paired servers.
Right now i have some problem because i can't find an explaination of some errors i can observe. Where i can find a detailed description of the error codes returned by the functions that have tBleStatus as return type?
In particular:
- aci_gatt_write_long_char_value return error 70 (decimal) after some working time (40min approximately). I have to disconnect and reconnect all the servers in order to restore the system.
- aci_gap_create_connection sporadically return the error 46 (decimal).
If you have some document where these return values are explained i will be very useful.
Thank you in advance
Best regards
Lorenzo
