STM32WB - How to calculate Max_Attribute_Records parameter
What is the general rule for computing the max attributes records parameter for:
aci_gatt_add_serviceCan you supply a general formula for all characteristic types:
#define CHAR_PROP_NONE 0x00U
#define CHAR_PROP_BROADCAST 0x01U
#define CHAR_PROP_READ 0x02U
#define CHAR_PROP_WRITE_WITHOUT_RESP 0x04U
#define CHAR_PROP_WRITE 0x08U
#define CHAR_PROP_NOTIFY 0x10u
#define CHAR_PROP_INDICATE 0x20U
#define CHAR_PROP_SIGNED_WRITE 0x40U
#define CHAR_PROP_EXT 0x80UThanks!
