Lep
Senior
Oct 26, 2022 8:54 AM UTC
STM32WB
I use my own board (as ble server) to notify the client, each notification is 120 bytes, I found that I can only transmit 30 per second. Actually my requirement is 100 transfers per second.
Do I need to modify anything?
Javier1
Principal
Oct 27, 2022 10:28 AM UTC
Jeeeesus @�?� 丫饼​ , read an APP note before spamming the forum with the same questions over and over.
Mabe you could use a MOOC also
hit me up in https://www.linkedin.com/in/javiermuñoz/
Lep
LepAuthor
Senior
Oct 27, 2022 10:43 AM UTC
The point is that no one is there to solve the problem, so I have to ask this question a lot.
Javier1
Principal
Oct 27, 2022 11:18 AM UTC
You are there to solve the problem :D
I really think you could use some reading before spamming the forum, just give it a go.
Maybe also put the time to guess if someone else had your same problem in the forum before, or to just put more than 20 seconds before badly formulating your questions and throwing them out there.
You will end up answering all your previous qestions before anyone else.
