~Amit~
Feb 3, 2020 3:03 PM UTC
STM32CubeMx generating sources with errors
I am trying to initiate a project via cubeMx for the STM32WB55 nucleo board.
I an able to initiate a simple project without the BLE middleware (STM32_WPAN).
Once adding the STM32_WPAN, the generated project not compiled on both Atollic true studio and system work bench.
Here is a link to a video demonstrating the issue.
I am using:
-CubeMX version 5.5.0
-Atollic true studio version 9.3.0
-WB package: STM32Cube_FW_WB_V1.4.0
Khouloud ZEMMELI
Khouloud ZEMMELIBest answer
Feb 4, 2020 8:19 AM UTC
​You're right , issue fixed in the 5.6.0 CubeMX version , the fix will be available in the next release.
Best Regards,
Khouloud.
Khouloud ZEMMELI
Feb 3, 2020 3:58 PM UTC
​Hello @~Amit~​  Thanks for the feedback, this will be internally checked.
best regareds,
Khouloud.
Khouloud ZEMMELI
Best Regards,
Khouloud.
~Amit~
~Amit~Author
Feb 4, 2020 8:22 AM UTC
Thank u for the quick response.
Can u estimate when is the next release?
Khouloud ZEMMELI
Feb 4, 2020 9:48 AM UTC
​The publication on st.com is planned in W08 .
Best Regards,
Khouloud
~Amit~
~Amit~Author
Feb 24, 2020 12:28 PM UTC
so the release did solve the the compilation error- thanks for that.
yet after adding a call to APPE_Init(); the software crashes when osKernelStart() invoked.
I am using:
  1. cube version 5.6.0
  2. STM32Cube_FW_WB_V1.5.0
  3. Atollic true studio version 9.3.0
  4.
please advise.
Aoruc.1
Aug 10, 2020 8:54 AM UTC
did you find any solution?
Aoruc.1
Aug 10, 2020 8:31 AM UTC
I have the same problem. I would like to know if you have found a solution.
I am using STM32WB55 microcontroller and when STM32CubeMX generates the code after after configuring "stm32_wpan"->"BLE", the debugger is stuck in an infinite loop in "startup_stm32wb55xx_cm4.s"
i used STM32CubeMX 6.0.0 and STM32CubeIDE 1.4.0
Thank you for your help,
best regards
~Amit~
~Amit~Author
Aug 10, 2020 10:45 AM UTC
I used one of the exampales and transform the ST scheduler to freeRTOS .
Attached is the transformed example.
hope it willl help u too.
Aoruc.1
Aug 10, 2020 12:05 PM UTC
I will try this now
thank you very much!
