ANair.19
Apr 24, 2026 10:41 AM UTC
STM32Cube FW_WL V1.5.0
I upgrade my project recently to the above firmware (STM32Cube FW_WL V1.5.0)  which ended up not working.
Lots of errors, I think mostly because of the introduction of the relay node.
After a couple of days trying to get this working I started a fresh project from CubeMX and this did not compile into the STM32WLE5CB.
Any idea on what the issue could be?
Apr 24, 2026 2:30 PM UTC
Hello @ANair.19
I suggest you debug and localize where the code hangs/stop and when it occurs.
You can share more details: which CubeMX version used, what is the error message, a screenshot of your issue, or your code/ioc file.
