JSalv.1
Oct 13, 2022 1:14 PM UTC
Stack BLE random crash on STM32WB
I have an STM32WB that is configured in central, it connects to 8 devices in peripherals mode at the same time. This configuration works well, but from time to time the BLE stack does not respond, I see 8 peripherals disconnected and I do not receive any event from the central stack. When I try to reconnect on the central side, the stack does not respond.
Have you ever had feedback on this kind of problem?
Sincerely,
Remy ISSALYS
Oct 28, 2022 4:04 PM UTC
Which stack and version are you using? Did you tune the connection interval for each connection?
Best Regards
