Nov 24, 2026 4:57 AM UTC
ST67W611M1 AT 1.0.0.1 (sdk 2.0.106): station module stops serving the SPI host
This is an update to the report above. We have reduced the failure to a much smaller setup, and one earlier statement of ours needs correcting.
Minimal reproduction (one module, no second ST67, no sockets).
  • One ST67W611M1, NCP reporting AT version:1.0.0.1 (Mar 20 2026 09:32:19), sdk 2.0.106, STM32H563 host, SPI host interface at 10 MHz.
  • The module joins an ordinary WPA2 home router as a station, with DHCP.
  • After +CW:GOTIP the host does nothing except send AT once per second. No CIPSTART, no sockets, no other commands.
AT+SYSSTORE=0
AT+CWMODE=0
AT+CWMODE=1
AT+CWDHCP=1,1
AT+CWJAP="<ssid>","<password>" -> +CW:CONNECTED, +CW:GOTIP, OK
AT (once per second, each answered OK)
AT -> no answer, RDY stays low
Result. Some time after the address is obtained, the module stops answering. The host clocks out the AT frame normally, RDY never rises, and every later command goes unanswered. Our SPI error counters (header sync, length, HAL errors) are all zero up to that point. Only a CHIP_EN restart recovers the module.
Time from +CW:GOTIP to the first unanswered AT:
AP Time to failure (s) Failures / trials
Commercial WPA2 router 91.5, 93.5, 103.5, 350.5 4 / 4
ST67W611M1 SoftAP (WPA2 or open) 72, 73, 107.5, 206.5, 210.5, 211.5, 238.5 7 / 7
The failure does not occur when the station has no DHCP address. With AT+CWDHCP=0,1 issued before AT+CWJAP (the station associates and AT+CIPSTA? reports 0.0.0.0), the same once-per-second AT was answered for 564 s, 643 s and 651 s in three runs, each ended by us. So the association alone is not sufficient; the module has to hold a DHCP-assigned address.
What does not change it.
  • The access point: a commercial router and an ST67 SoftAP behave the same.
  • Encryption: WPA2 and open SoftAP both fail.
  • Traffic and sockets: none are needed.
  • Power save: with AT+PWR=0 issued both before AT+CWJAP and again right after +CW:GOTIP (both answered OK), the module still failed at 217.5 s, 304.5 s and 377.5 s (3 of 5 trials; the other two were ended by us at 364 s and 385 s). AT+PWR? answers ERROR in this build, so we could not read the state back.
  • Broadcast traffic: a PC on the same network captured all broadcast frames with Wireshark across two failures. No broadcast frame was on the air in the second before either failure. The station itself sent only its DHCP Discover/Request and one gratuitous ARP at join time.
  • From the earlier report: SPI clock (10/20/40 MHz) and DHCP lease time.
Correction to our earlier report. We described the failure as occurring "exactly 60 s after AT+CIPSTART". That regular timing holds when a TCP link is open and carrying data (59–63 s in every cycle). Without any socket the time to failure varies widely, as the table shows. We also implied the ST67 SoftAP was part of the condition; it is not.
Questions.
  1. Can you reproduce this with the sequence above? It needs only one module and any DHCP-serving AP.
  2. What does the NCP do periodically once the station interface has a DHCP address (lease bookkeeping, ARP maintenance, power-save entry) that could block the SPI/AT task?
  3. Is there a setting that avoids it, short of disabling the DHCP client? A static station address would help us, but in this build AT+CIPSTA is accepted and the interface stays at 0.0.0.0 after the join (reported earlier in this thread).
  4. Is a newer NCP binary available or planned in which this is addressed?
We can provide full host logs for every trial listed and the Wireshark capture.
Thank you.
