TA.1
Setting up the radio to sniff raw wireless M-bus packages
Hi all,
Is it possible to setup the radio on the STM32WL5x to sniff raw wireless M-bus packages?
I do not want to transmit any data, just receive raw packages from meters that are in range.
Thank you in advance.
Tesla DeLoreanBest answer
September 6, 2023
The Semtech chips operate in a promiscuous mode, they hear all radio traffic.So you can listen to packets on the air.
What you NEED to do is configure all the radio parameters, ie frequency, bandwidth, spread-factor, preamble, etc to match identically those of the transmitter you're trying to listen in on.
Find details on the protocol expectations, or find source for other/related Semtech radios.
September 6, 2023
Issamos
Hello @TA.1
The best way is to buy the stack from Stackforce or to use the X-CUBE-SUBG1 exemples and migrate them to the stm32wl ( is not so hard to do it).
To find more details about the Stackforce and stm32wl take a look at this post.
Best regards.
II
