Setting MSI,HSI or HSE and configure clock speed of SYSCLK ,HCLK and other cloks.
Hello, I have a stm32wb55 nucleo board,
I want to know that whats is the logic behind that , In reference manual it says
After a system reset, the MSI oscillator, at 4 MHz, is selected .
Lets say I want to use HSI or HSE for specific application and I want to set SYSCLK, HCLKs and other clocks .
How can I implement a code that configure HSI,HSE selection and SYSCLK etc.
I want to do that using LL(low layer libraries).
Thanks for your helps
