frackers
Senior
Dec 9, 2018 11:23 PM UTC
Setting MAC address on SPBTLE-RF using hci_le_set_random_address does nothing
I'm trying to set the application specific 'random' MAC address on the SPBTLE-RF using hci_le_set_random_address() but I always end up with an address of all FF's.
If however I use aci_hal_write_config_data() it works as expected (I get an address starting 0xc0....)
Should I be using both methods?
    sagar verma
    Jan 11, 2019 6:31 AM UTC
    I have exactly same problem, can anyone suggest the solution ?
    I mean how to set the random static address, what is the call flow?
    rds-tmeyer
    Dec 27, 2021 4:34 PM UTC
    Have you been able to solve your problem? I've a similar issue on my side. hci_le_set_random_address does not have any effect on the BlueNRG2 with Stack 2.1c
