ahmed1
Aug 27, 2018 1:19 PM UTC
send a simple message like "hello" with lorawan cube to TTN
Hello ,
I use this demo board B-L072Z-LRWAN1 with the soft End Node I-CUBE-LRWAN 1.2.0
But I do not understand why I cant send the message
i disable all senser and i try to send with
" LORA_send( &AppData, LORAWAN_DEFAULT_CONFIRM_MSG_STATE); "
in static void Send( void )
Thank you.
Matthias Schranz
Sep 12, 2018 5:52 AM UTC
did you check all the keys and proper registration of the node in the TTN-Console?
Huzaifah Limbada
Dec 21, 2018 5:26 AM UTC
You can also refers the logs of your gateway.
