Mar 5, 2024 12:44 AM UTC
Secure Flash Area Approach
Hi.
Something that needs to be done FOTA while using the code, so you need to write the flash area behind it.
I want to use a sash area, but it is impossible to access the document.
Please tell me if you have a way to do it.
songkwBest answer
Apr 23, 2024 5:09 AM UTC
I wanted to flash write in the WirelessStack area, but I gave up because I found it impossible.
Thank you.
STTwo-32
Apr 18, 2024 4:16 PM UTC
Hello @songkw
Can you give more details about your request?
Best Regards.
STTwo-32
songkwAuthorBest answer
Thank you.
