GEORGE SANDLER
Aug 28, 2018 11:53 AM UTC
Same problem with current consumption in stop mode using B-L072Z-LRWAN1
Question isn't new, but I couldn't find the answer in existing threads.
The stop current on the Discovery Kit loaded with End_Node project is above 3 mA. The low power mode is enabled; jumpers in correct positions; software version 1.1.5
Getting same results on our custom board.
Can anyone provide an explanation what to look for in the source code? Also it will be helpful to get a simple binary doing nothing: disabling TCXO; and putting CPU in the Stop mode.
ldeti
Sep 21, 2018 11:10 AM UTC
Do you have find a solution?
Same issue here.
