RTC_AlarmIRQHandler not working in BLE applications on STM32WB MCUs
I am having issues with RTC Alarms in BLE applications on my STM32WB boards. If BLE isn't turned on, the alarms work correctly. When I turn BLE on, the alarms stop working. After some debugging, I found out that the RTC registers are set up correctly, and the alarms trigger their respective hardware interrupt flag, but for some reason RTC_AlarmIRQHandler doesn't get executed. This behavior happens in both my custom BLE application and the example BLE applications CubeMX can generate. Does anyone have any tips what the issue might be? Thanks.
Edit: Forgot to mention MCU types: one board has a WB50CGU, the other one a WB55CGU.
