Nov 10, 2026 2:05 AM UTC
Request for PDMFilter CM33 Keil wc32 library
Dear ST Support Team,
I am developing an audio application for STM32WBA (Cortex-M33) using Keil MDK with Arm Compiler 6 (ArmClang).
I currently have the following library:
libPDMFilter_CM33_Keil_wc16.lib
However, my project requires the default 32-bit wchar_t configuration and cannot use the -fshort-wchar compiler option.
Could you please provide the corresponding library:
libPDMFilter_CM33_Keil_wc32.lib
Alternatively, is there an official source-code version of the PDMFilter library that can be compiled with ArmClang using the default 32-bit wchar_t configuration?
Thank you for your assistance.
Best regards
Nov 17, 2026 3:49 PM UTC
Hello ​@eehorizon and welcome to the Community,
An internal ticket number: CDM0067568 is submitted for your request.
I'll keep you updated here about the progress.
(PS: ticket number: CDM0067568 is only for reference, not available outside of ST)
