Peter BENSCH
Peter BENSCHBest answer
Jan 16, 2024 2:28 PM UTC
Apart from the slightly higher capacitance values, which probably don't play a major role in this board as only DC is switched, the FSA usually shows even better values than the NX3, so in my opinion you should be able to use the FSA5157.
Hope that helps?
Good luck!
/Peter
Peter BENSCH
Hope that helps?
Good luck!
/Peter
Levan
LevanAuthor
Jan 17, 2024 7:29 AM UTC
Thank you Peter for your answer. Appreciate!
