Aug 17, 2024 8:07 AM UTC
Problem with broadcast ADV_DIRECT_IND
IN demo P-NUCLEO-WB55.Nucleo\Applications\BLE\BLE_p2pClient ,After receiving the server's broadcast data, we hope to send targeted broadcast data to the server.
M0stack:stm32wb5x_BLE_Stack_full_fw.bin
When I use the following function to test, the error return value is 1,Using ADV_IND broadcast can be sent normally
  ret = aci_gap_adv_set_configuration(0x01, 0x00, 0x04, 0x20, 0x20, 0x07, 0x00, 0x00,&server_remote[i].SERVER_REMOTE_BDADDR[0],0x00, 0x00, 0x00, 0x01, 0x00, 0x00);\
 APP_DBG_MSG("ret = %d\n",ret);ret = 0x1
 ret = aci_gap_update_adv_data(sizeof(a_ManufData), (uint8_t *)a_ManufData);
APP_DBG_MSG("ret = %d\n",ret);//ret = 0x0
Adv_Set_t adv_set;
adv_set.Advertising_Handle = 0x0;
adv_set.Duration = 0x0;
adv_set.Max_Extended_Advertising_Events = 0x0;
ret = aci_gap_adv_set_enable(0x01, 0x0, &adv_set);
STTwo-32
Sep 4, 2024 4:57 PM UTC
Hello @jiefeng_wang
Could you give more details about your Implementation, the changes you have made on the Code, what you see exactly on the trace exactly, When the error happen, ...
Best Regards.
STTwo-32
