Problem flashing a card STM32WBA55G
- 3 replies
- 2041 views
I have a STM32WBA55G card and I want to flash an example code but it doesn't work. So I used STM32Programmer to find out why my board wasn't "found". Normally STLink is included and I can go through the usb-c port. But I still get an error if I go through the uart connection: "Error: Activating device: KO. Please, verify the boot mode configuration and check the serial port configuration. Reset your device then try again... »
Et j’ai toujours l’erreur suivante si je passe par stlink : « Error: No STM32 target found! If your product embeds Debug Authentication, please perform a discovery using Debug Authentication »
I can't find the solution, can you help me?
Best regards
