Problem between RTC and Timers generating PWM
Hi Everybody!
New with STM32, i'm currently working on a project in order to combine black line detection with an AlphaBot and IA embedded with a TOF sensor, all of that with a Nucleo-WB55.
Actually I would like to add a Bluetooth function to be able to read informations about all the sensors.
The matter is : When I enable my RTC (mandatory with BLE), my timers (used to generate a PWM for the wheels motors) doesn't work : The right one doesn't move but the other one is at 100%.
Have you an idea of something to check?
Thank you!
