Mar 21, 2024 1:11 PM UTC
Pre-loaded FUS version in STM32WB55CGU6TR
is it right that STM32WB55CGU6TR is already pre-loaded with FUS v1.2.0.0?
STTwo-32
STTwo-32Best answer
Mar 21, 2024 3:33 PM UTC
Every STM32WB include the last FUS Version available the day it was made. When using the Cube Programmer, the FUS is not automatically updated, you have to follow all steps mentioned on the wiki. If your question is answered, Close the topic by selecting a best answer.
Best Regards.
STTwo-32
STTwo-32
Mar 21, 2024 1:51 PM UTC
Hello @strawi03 and welcome to the ST Community :smiling_face_with_smiling_eyes:.
Not sure, it depends on the manufacturing date and the available firmware. To understand which is the version on each MCU. It will be a good idea to check the version using Cube Programmer and following this wiki.
Best Regards.
STTwo-32
strawi03Author
Mar 21, 2024 2:33 PM UTC
Hello @STTwo-32,
thank you and thanks for the quick reply.
Check with STM32CubeProgrammer results in v1.2.0.0.
So then it is clear.
I thought the STM32CubeProgrammer might automatically upgrade the FUS to the latest version.
However, this does not appear to be the case.
Thanks and regards,
strawi03
STTwo-32
STTwo-32Best answer
Best Regards.
STTwo-32
