Powering NUCLEO WB55 externally
Hi! I have a nucleo WB55 board that I am using for a project. I know with other nucleo boards, it is possible to power them externally with 5V or 7-12V. However, I am not able to verify whether this is possible on the NUCLEO WB55 board, as I can't find the external power supply guidance/instructions in the User Manual.
My aim is to power the board directly with either 12V or 5V but I don't know if this is doable, or the how I could go about it if it is. Please let me know your thoughts.
Peter BENSCH
Peter BENSCHBest answer
Welcome @odianosen_o, to the community!
Yes, you can also supply the NUCLEO-WB55RG externally with 5V or 7...12V. Unfortunately, this has not (yet) been noted in the manuals, but you will find a hint in the schematics (to be found in tab CAD Resources) on page 5: there are two options for the external voltages 5V_EXT (CN7.6) and VIN (CN7.24) on the MORPHO pins.
The MORPHO connections are the external pin rows, which provide significantly more pins than the limited Arduino pins.
Hope that helps?
/Peter
Peter BENSCH
Hope that helps?
/Peter
Thanks so much for this! Follow up question based on externally powering the nucleo board. If I want to debug or program the board, would I have to disconnect the external power before plugging in the USB to my PC/ hooking up to ST-Link?
Peter BENSCH
No, there‘s a jumper block selecting the supply voltage. Just move it to the required position.
