Feb 27, 2025 10:14 AM UTC
PCB Antenna Design for STM32WL55 at EU868 – Guidance Needed
Hello STM Community,
I am designing an internal PCB antenna for LoRa communication using the STM32WL55JCI7 at EU868 frequency. Is a PCB antenna recommended by STM for this chip? If so, what guidelines or procedures should I follow for designing a PCB antenna for LoRa communication? Additionally, what range can I expect with an optimized PCB antenna design?
Looking forward to your insights. Thanks!
STTwo-32
STTwo-32Best answer
Mar 25, 2025 12:01 PM UTC
Hello @Nikunj_17
There is not a particular design guide dedicated for antenna. But I may recommend you the:
You can also refer to the antenna of the MB1389.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Hello @Nikunj_17
Best Regards.
STTwo-32
Nikunj_17Author
Mar 26, 2025 3:21 AM UTC
Thank you so much for your recommendation! Do you also have any reference board for a PCB antenna designed for LoRa communication at EU868?
STTwo-32
Mar 26, 2025 9:05 AM UTC
Such a design does not exist, but you can refer to the antenna design of the MB1389 that I've mentioned on my first comment.
Best Regards.
STTwo-32
