Nov 13, 2024 2:14 PM UTC
NUCLEO-WL55JC reset when laptop attached to it.
I use the NUCLEO-WL55JC STM32WL Nucleo-64 board, which I supply with an external power supply.
Each time I attach my laptop in order to view the console, the WL55JC is reset. I assume the STLINK-V3E issues a reset to the WL55JC.
Is there a possibility to avoid that?
I tried to take away the jumper that allows T_NRST to be connected to ST-LINK, but then, when I attach my laptop the board, the WL55JC enters an unusual state (it neither continues normal operation nor does a reset). Except for this I did not find any other ideas how to change the behavior. Is there any?
HOPilsanBest answer
Nov 13, 2024 3:01 PM UTC
First I left SWDIO and SWCLK, then I removed them. No change.
Yep, a good idea o check the voltages. I'll do that.
Andrew Neil
Nov 13, 2024 2:18 PM UTC
What "console" are you using?
HOPilsanAuthor
Nov 13, 2024 2:26 PM UTC
It is LPUART1 which is tunneled by the ST_LINK through USB to my laptop.
Andrew Neil
Nov 13, 2024 2:46 PM UTC
Does the board have jumpers/solder-bridges to disconnect the NRST from the ST-Link to the target?
Or use a separate USB-to-UART adaptor.
Sco
Nov 14, 2024 5:49 AM UTC
You mentioned you " take away the jumper that allows T_NRST to be connected to ST-LINK", would you confirm which jumper you removed?
BTW, if you assume it's impacted by the NRST, another way is to monitor this signal to see if there is a drop when the reset happens.
HOPilsanAuthor
Nov 14, 2024 7:56 AM UTC
It was jumper JP8 position 9-10. I'll check both NRST and the voltages and give feedback.
Andrew Neil
Nov 14, 2024 9:17 AM UTC
