Jul 12, 2025 11:22 AM UTC
NUCLEO WBA52CG No device found on target
Hello ,
I'm trying to flash in the NUCLEO WBA52CG the basic code example available in STM32CubeIDE. I use version 1.19 with Windows. It was originally version 1.17 and was updated in 1.19.
No issue to generate the code or build it. I then connected the NUCLEO WBA52CG and wanted to flash in the board.
I got the failure message "No device found on target."
Can anyone help me ?
I added below a pictures of the connected board. Some leds ( green and red ones) are blinking but I don't know if it's OK or not
Thanks in advance
Serge
Serge1Best answer
Jul 17, 2025 1:25 PM UTC
Hello
After uninstalling STM32CubeIDE version 1.17 updated in version 1.19 and installing version 1.19 directly from the scratch it’s working fine.
Thank you for your help
Regards,
Serge
STTwo-32
Jul 12, 2025 12:03 PM UTC
Hello @Serge1
does it work fine with the STM32CubeProg V2.20.0 (try different mode such as the under reset, normal…).
Best Regards.
STTwo-32
Jul 14, 2025 4:56 PM UTC
This post has been escalated to the ST Online Support Team for additional assistance. We'll contact you directly.
Regards,
Christian
Serge1AuthorBest answer
Hello
Regards,
Serge
