Nov 19, 2024 1:48 PM UTC
nucleo wb55rg BLE Not Working
Hello Community,
Greetings of the day.
I'm using the Nucleo WB55RG board. I'm trying to initialize and connect the wb55rg BLE with my mobile app.
So, I'm following the stm32wb getting started video series, video part-12b.
(video link - https://youtu.be/CKYWy7LKL68?si=_UNNvolzgO88g9_H).
I did exactly what's done in this video. I Generated the code, Build & Run it using STM32cubeIDE. I got NO error in the code.
But still, I could not see the name of my BLE device on ST BLE Toolbox app.
Why is this exactly happening? Possible reasons?
Any alternative procedure/approach is most welcomed. Share your experience.
STTwo-32
STTwo-32Best answer
Nov 30, 2024 2:36 PM UTC
Hello @OS_Er
I think this link will be the best choice for you.
Best Regards.
STTwo-32
STTwo-32
Nov 26, 2024 10:14 AM UTC
Hello @OS_Er
I suggest you follow the steps mentioned on this wiki and change your code according to them (it will be even better to start from a new project). It should be working fine.
Best Regards.
STTwo-32
OS_ErAuthor
Nov 28, 2024 1:41 AM UTC
Hello @STTwo-32
Thanks a lot for responding :folded_hands:.
I  have already folllowed the steps exactly from the st wiki page link you mentioned as well as in the end I followed the video I mentioned.
I tried this Link as well which is the BLE example code repository. (https://github.com/abluethinginthecloud/STM32WB-custom-ble-examples)
But still I'm facing the same issue.
Do you think I'm missing any hardware configuration on the board?
  Or there's any issues on my board?
Thank you :smiling_face_with_smiling_eyes:
STTwo-32
Nov 28, 2024 4:39 AM UTC
Hello @OS_Er
Have you updated your FUS and STACK .bin files to the last version. If not, could you please follow this WIKI. to update both BLE FUS and STACK (don't forget to start your wireless stack at the end using the "Start Wireless Stack" button so you make everything works fine). For the example of test you can use the https://github.com/STMicroelectronics/STM32CubeWB/tree/master/Projects/P-NUCLEO-WB55.Nucleo/Applications/BLE/BLE_p2pServer (take a look at the readme file of the project to know what .bin file to use for the stack update and where to find it).
For the project, import it from CubeMX (on the example selecter) and open it on CubeIDE (use the V1.17.0 for the IDE, V6.13.0 for the MX and V1.21.0 for the STM32CubeWB).
Best Regards.
STTwo-32
OS_ErAuthor
Dec 2, 2024 9:15 AM UTC
Hello @STTwo-32
Thank You Very Much
My BLE started working.
Eurekaa !!!
