Nucleo WB55RG BLE Mesh
I'm starting using BLE Mesh on Nucleo wb55rg, I've seen the STM32CubeWB Package and in it there are tools for getting started with a BLE mesh Network. Following the steps in this wiki I get a small error.
- I'm uploading code for Friend Node
- I'm uploading code for Low-Power Node (after modifying the associated code)
- When push the button 1 (like explain on the wiki) I have this error:
"elementAddress" failed: file "../../../../../../Middlewares/BLE_Mesh_Lib/pal/STM32WB/pal_crypto.c", line 3170, function: MoblePalCrypto_GetModelPublicationParameters
- The rest of the operation presented in the wiki is not done
Note: I don't use exactly the same references as the wiki
I have 2 Nucleo WB55RG (one it's Friend Node and other is LP Node), not a nucleo and a p-nucleo
After searching on the internet I still don't understand where this error comes from.
Thank you for you reply
