AWack
Aug 28, 2024 3:03 PM UTC
NUCLEO-WB09KE and STM32CubeMX generating wrong HAL files
I just try to get a NUCLEO-WB09KE board running.
Unfortunately CubeMX (6.12.0) generates HAL files with a pattern of stm32wb0x_hal...,h but the include paths are stm32wb00x_hal (one more zero!)...
Also in CubeIDE EXTI_HandleTypeDef is not found when compiling.
Best regards,
Achim
Sep 3, 2024 10:25 AM UTC
Hello @AWack
Thank you for reporting.
Actually, this issue has been reported internally to Dev team for correction (under internal ticket number 190038 ) and it will be fixed ASAP.
Thank you!
Mahmoud
Aug 28, 2024 4:55 PM UTC
Hello @AWack ,
First let me thank you for posting.
Your request is under investigation, and I will get back to you ASAP.
Thanks.
Mahmoud
Aug 29, 2024 1:57 PM UTC
Hello @AWack ,
I am not able to reproduce your issue by creating a project with NUCLEO-WB09KE board.
I suggest that you provide your ioc.File.
Thanks.
Mahmoud
AWack
AWackAuthor
Aug 29, 2024 2:00 PM UTC
