Joan Duran
Nov 15, 2024 6:39 AM UTC
New device callback in Zigbee
Using the Zigbee stack as a coordinator, is there a callback available to notify when a new device is associated in the network?
We observe the following in the M0 log:
[M0] [00000015.076][PLATFORM] nwk_handle_assoc : Association accepted, sending response (0xb0dc, 0xa4c1383054f9cec1)
We can detect the new device in the ZB_NWK_NIB_ID_NeighborTable, but having a callback to trigger on association would be very helpful. I've checked the documentation and examples but haven’t found any information on this.
Thank you!
OuadiBest answer
Nov 15, 2024 11:55 AM UTC
Hi @Joan Duran,
You can use ZbMsgFilterRegister API at the startup (inside the func APP_ZIGBEE_StackLayersInit) to register the callback you want to use to retrieve any network status change.
Please find below an example to detect a new device join :
ZbMsgFilterRegister( stZigbeeAppInfo.pstZigbee, ZB_MSG_FILTER_JOIN_IND, ZB_MSG_DEFAULT_PRIO, APP_ZIGBEE_DeviceJointCallback, NULL );
static enum zb_msg_filter_rc APP_ZIGBEE_DeviceJointCallback( struct ZigBeeT * zb, uint32_t lId, void * pMessage, void * arg )
 struct ZbNlmeJoinIndT * pstJoinMessage;
 if ( lId == ZB_MSG_FILTER_JOIN_IND )
 pstJoinMessage = ( struct ZbNlmeJoinIndT * )pMessage;
 switch ( pstJoinMessage->rejoinNetwork )
 case ZB_NWK_REJOIN_TYPE_ASSOC :
 case ZB_NWK_REJOIN_TYPE_ORPHAN :
 case ZB_NWK_REJOIN_TYPE_NWKREJOIN :
 case ZB_NWK_REJOIN_TYPE_NWKCOMMISS_JOIN :
 case ZB_NWK_REJOIN_TYPE_NWKCOMMISS_REJOIN :
 /* A new Device has Join Network at MAC/NWK level */
 APP_ZIGBEE_SetNewDevice( pstJoinMessage->nwkAddr, pstJoinMessage->extAddr, pstJoinMessage->capabilityInfo );
 break;
 default :
 break;
 return( ZB_MSG_CONTINUE );
Best regards,
Ouadi
Nov 15, 2024 7:45 AM UTC
Use the emberIncomingMessageHandler() callback to listen for ZDO_Device_Announce messages. Or you can also use  emberAfPluginNetworkSteeringDeviceJoinedCallback() (if using the Network Steering plugin) to detect when a device has joined.
OuadiBest answer
Hi @Joan Duran,
 break;
 default :
 break;
Best regards,
Ouadi
