My debugger is lost after SystemApp_Init() initialization...
I am a newbie in ST boards/products.
I am using the NUCLEO-WL55JC board. I found an example to try. However, I can not work with it.
After I open the example, I choose "Debug As: STM32 App". It is uploading the code, and the debugger connects... I can go step by step until DBG_Init() function in SystemApp_Init() function. Then, DBG_Init() tries to change my debugger pins behaviors. Then, "Target is not responding, retrying..." message appears in the console.
What should I do?
