Mar 6, 2025 8:59 PM UTC
MXCHIP EMW3080 on B-U585-IOT02A with Zephyr
Hello, I am using the B-U585-IOT02A board with Zephyr. I can't see how to use the MXCHIP EMW3080 Wi-Fi chip. Has anyone made this work? Thanks
Mar 7, 2025 9:02 AM UTC
Hello @stuart_rubin_ns,
for the WIFI module: you can get the firmware on this link and then follow the procedure describe in the UM to program the WIFI module.
Also, you can find more details in the datasheet provided by MXCHIP: EMW3080-DS0069EN.pdf
Mar 7, 2025 6:10 PM UTC
Sarra, thank you for your reply. Unfortunately, my issue is specifically with using Zephyr. This board (B-U585-IOT02A) does have Zephyr support, but it's not obvious for how to use Wi-Fi with Zephyr. Do you have any information on that? Thank you.
Explorer II
Nov 25, 2025 2:11 PM UTC
Hi Stuart. Did you manage to get this working under Zephyr? I am using the STMH7S78-DK board and want to use WiFi with the MXCHIP EMW3080 but stubbed against the same wall as you. Thanks in advance.
