Dec 4, 2024 7:41 PM UTC
Missing stm32wbxx.h in beacon project
Greetings
I have a STM32WB55 P-Nucleo board, with the STM322B55 dongle. I am trying to flash the beacon project onto the nucleo board.
I have downloaded the STM32WB repo from the github link
I unzipped the file and selected the .project from the following route:
STM32CubeWB-master\Projects\P-NUCLEO-WB55.Nucleo\Applications\BLE\BLE_Beacon\STM32CubeIDE.
I tried building the project but errors are thrown that entails the file stm32wbxx.h is missing. How can I solve this?
STTwo-32
STTwo-32Best answer
Dec 6, 2024 8:05 PM UTC
Could you please try to import it using the following Methode:
Go to File > Open Projects from File System... > and select the directory of your project. After that, on the Folder file select the STM32CubeIDE folder. "
Best Regards.
STTwo-32
STTwo-32
Dec 4, 2024 7:46 PM UTC
Hello @ZAIDS-S23
I've answered your question on this FAQ. If it solve your issue, a kudo From you on the wiki will really help to make it visible for others who have the same behavior.
Best Regards.
STTwo-32
ZAIDS-S23Author
Dec 6, 2024 5:51 PM UTC
Hi
I've taken your advice and cloned the git repo as per the answer you gave. I opened the .proj file for the Beacon, and tried building the project. I get the following error:
non constant or forward reference address expression for section .ARM.extab
Any way to solve this error?
STTwo-32
Dec 6, 2024 5:58 PM UTC
Could you please open .cproject file or call it directly using the import project of the STM32CubeIDE.
Best Regards.
STTwo-32
