Toximik
Sep 26, 2024 5:49 PM UTC
Missing CO2 ZCL cluster in Zigbee library
I have started project with NUCLEO-WB55RG, which i planned to use as Zigbee router for my Home Assistant. I have manage to get temperature  working, then I wanted to add CO2 value (measured by SDC30 sensor) as next step but i have found out that CO2 cluster is missing from ZCL headers files provided by ST. So my question is: Does ST provide more up-to-date ZCL Cluster library or it is it possible to implement ZCL cluster for CO2 myself? Or there is some other solution?
Thanks for any advice.
Joe WILLIAMS
Sep 27, 2024 5:33 PM UTC
Hi Toximik
This post has been escalated to the ST Online Support Team for additional assistance."  Add a sentence "Should anyone else have a similar  question, please submit your request directly to the ST Online Support Team at https://my.st.com/ols
Joe
STMicro Support
STTwo-32
Oct 18, 2024 4:21 PM UTC
Hello @Toximik
The Carbon Dioxide (CO2) (cluster identifier from section 4.13.1.3 in ZigBee Cluster Library Specification rev. 8 https://zigbeealliance.org/wp-content/uploads/2021/10/07-5123-08-Zigbee-Cluster-Library.pdf#page=367) cluster identifier that you are mentioning is part of the Concentration Measurement (a collection of 32 subcluster), which is not implemented in our solution as of today.
Thus, from my perspective, you will need to implement it by yourself, by following the AN5491.
Best Regards.
STTwo-32
