Jun 20, 2025 7:29 PM UTC
Matching networks
Hi
Im a bit new and have som RF related question.
I am doing a heart monitoring project where i want to measure ECG signals, put it through my AFE (analog frontend), then into the ADC inside the MCU and then output the data through BLE into a phone.
I am using STM32WB55CEU6. My question is: Is it very important to get the two matching networks correct (one for the RF pin and one for the antenna)?
Can i just copy the matching networks from the reference example in the application notes of the MCU and the antenna even though im using different PCB-stackups?
I don't know enough about RF to design my own matching network. Keep in mind i just want to make the BLE work, im not trying to have optimal performance.
Thanks in advance.
STTwo-32
Jun 23, 2025 9:18 AM UTC
Hello @siyar
To optimize the BOM RF performance, two matching networks are required. To understand how to configure those RF matching network, i suggest you have a look at the chapter 8 of the AN5165.
Best Regards.
STTwo-32
