OTudo.1
Nov 14, 2021 4:42 PM UTC
LSE enable for STM32WLE5CCU6
I am trying to activate LSE in a project with STM32WLE5CCU6, the pins PC14 and PC15 are activated, but in the window with clock tree, the RTC clock mux does not alow me to select LSE (it is locked on LSI). This happens even if all other pins are unused. I am using CubeMX version 6.3.0.
Does anybody encounter this problem? I am doing something wrong? Can anyone check?
Thank you
Mike_ST
Mike_STBest answer
Nov 15, 2021 11:20 AM UTC
Please activate the RTC in the Timers section, and select, "activate clock source".
Nov 14, 2021 11:43 PM UTC
You need to enable the LSE in System Core -> RCC first, then you can select it as a clock source.
OTudo.1
OTudo.1Author
Nov 15, 2021 7:09 AM UTC
Thank you for answering,
That is exactly how I set it up, I selected Crystal for LSE clock, but in Clock configuration page RTC Clock Mux is still locked.
I had attached the ioc file.
Mike_ST
Mike_STBest answer
OTudo.1
OTudo.1Author
Nov 15, 2021 4:40 PM UTC
Thank you,
Now I understand how to activate it.
