LoRaWAN_End_Node: varying configuration
Hello everyone,
I am now working with LoRaWAN_End_Node on Nucleo-WL55JC1 and I found no place to change configuration such as BW, TX power, Spreading Factor, etc. in this example (Probably, I found at wrong places).
Is it possible to change those factors in this example and if not, is there other example from MX I can do that?
Kind regards,
Huy Nguyen.
