Dec 20, 2024 11:44 AM UTC
Lorawan class change
In our end-node application, the device occasionally needs to switch its operating class from Class A to Class C. This class switching is triggered by an external interrupt rather than a downlink message from the server.
To achieve this, I am using the LmHandlerRequestClass() function from the LoRaMAC layer, which successfully switches the device to Class C. However, on the next Tx cycle, the device reverts back to Class A.
How to ensure that the device remains in Class C after the class switch?
STTwo-32
STTwo-32Best answer
Jan 22, 2025 5:37 PM UTC
Hello @pho3nix
Using the LmHandlerRequestClass() function should do the job. Could you please give more details about your issue.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Hello @pho3nix
Best Regards.
STTwo-32
Aug 5, 2025 8:16 AM UTC
Have you solved this problem, friend? Well, I'm also facing this issue right now. I failed to switch to class C.
