AChud.3
Oct 23, 2021 11:02 AM UTC
LoRa end node and gateway with NUCLEO-WL55JC1.
I have two NUCLEO-WL55JC1 boards with me. I want to make one board as a end device and one board as a gateway. I found end node example with in firmware package of STM32WL but not found any example for gateway.
Is there any gateway example available for NUCLEO-WL55JC1?
Is this board(NUCLEO-WL55JC1) capable to run gateway example on it?
Please help me to resolve above questions.
Thanks,
Ankit
Nov 3, 2021 11:31 AM UTC
Hello @Community member​
The STM32WL55 is a the device is radio based on Semtech SX126x. The 'commercial' gateway as usually based on SX1301. I am not aware of a projet supporting shield with Wifi/Ethernet to allow NUCLEO-WL55JC1 to become a 'single channel LoRa gateway' as packet forwarder like I-NUCLEO-LRWAN1 LoRa® HF band (868/915/923 MHz) sensor expansion board (https://www.st.com/en/evaluation-tools/p-nucleo-lrwan2.html) based on the STM32L052 MCU + Semtech SX1272 transceiver.
Hoewer, there is a ping/pong example to allow communication between your two STM32WL nucleos.
BR,
Bruno
