Sammalisto.Pauli
Jan 14, 2024 3:32 PM UTC
Lora-E5 mini system clock
I am testing Lora-E5 mini with FreeRTOS from LoRaWan-E5-Node-qian example in STM32CubeIde . All works fine except the clock (MSI) is only 4 MHz.  This causes that e.g. osDelay(100) takes 4 s.
I have been trying to change MSI to HSE 32 MHz, but no luck. Does someone know, how to change the clock.
There is an ioc file, but use of STM32Cube will ruin the project.
STTwo-32
STTwo-32Best answer
Feb 13, 2024 8:01 AM UTC
Hello @Sammalisto.Pauli
Sorry for my late replay. I suggest you to ask the same question on the seeed studio forum for more details since they are the owner of this product based on the STM32WL MCU.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Best Regards.
STTwo-32
Sammalisto.Pauli
Feb 13, 2024 8:35 PM UTC
Hi STTwo-32,
thank you for your reply.  I eventually managed to make it to work.  I started from the beginning with CubeMX and then I copied the driver files from seeed studio example.
Best regards
Pauli Sammalisto
STTwo-32
Feb 13, 2024 8:42 PM UTC
Good to know that @Sammalisto.Pauli
If so, could you please choose a best answer to close this post.
Best Regards.
STTwo-32
Dec 22, 2024 10:05 AM UTC
Hi I'm facing issues with using cubemx to initialize peripherals with FreeRTOS from LoRaWan-E5-Node-qian, whenever I change anything in cubemx and generate code I get lots of build errors. I am also using Wio E5 mini.
