Is there firmware to support EMC testing of an STN32WL55JC based LoRa device?
Specifically I need to be able to set continuous transmission at full power using each end of the band.
I also need to perform immunity tests, but I don't know how to get information out of the device at a suitable rate, short of having a physical cable on a UART, which would mess with the normal configuration, affecting EMC behaviour.
Has anyone done this before?
