Is there any way just use LoRa communication with B-L072Z-LRWAN1?
Hello to everyone,
I don't have a gateway but two B-L072Z-LRWAN1 kits. So I am trying to send a sensor data between these kits. ST has i-cube-lrwan library for kit but it is not compatible with CubeMX and very complex because of LoRaWAN. I have used ping-pong example but when try use ADC or I2C I have failed. Is there any way, library, use these kit only for LoRa communication compatible with CubeMX.
Thanks for help.
