Andrew Neil
Sep 12, 2025 9:40 AM UTC
Welcome to the forum.
Please see How to write your question to maximize your chances to find a solution for best results.
@harikrish wrote:
I’m new to using the I-CUBE-LRWAN library
Before getting into I-CUBE-LRWAN, get the sensor working on its own with just the STM32L476RG.
Then get started with  I-CUBE-LRWAN by using it as-is, with the built-in supported sensors.
Try it out; examine the code; learn how it does its sensor interfacing.
Then you can replicate that with other sensors...
