Senior III
Jan 27, 2026 4:13 PM UTC
I2C1 has decided to stop working?
NUCLEO WB55
For an unknown reason I2C1 has just stopped working. The BLE & UART are working but the boards (I've tested on 2 identical boards) are no longer talking to the sensors via I2C.
When I scope them up the traces for SCL & SDA are both flat lines (yes I checked the scope is working properly).
Frustratingly, this all worked before xmas.
Anyone any clue what could cause this?
NicRobertsBest answer
Senior III
Jan 28, 2026 1:26 PM UTC
Found it just now, a short across SDA & SCL seems to have blown I2C1, I2C3 and everything else is working fine.
Andrew Neil
Jan 27, 2026 4:19 PM UTC
Some more details of your setup would help:
How to write your question to maximize your chances to find a solution
So what have you changed between then & now ?
High or low?
Can you toggle them just as plain GPIOs
NicRobertsAuthorBest answer
Senior III
