Shahin
Dec 13, 2022 3:02 PM UTC
I would like to use the custom template for BLE on the WB10, however I believe the GAT values need changing, has anyone managed to do this?
Similar to this post - https://community.st.com/s/feed/0D53W00001nnAMrSAM?t=1670943529113.
I believe different values is needed for:
  • CFG_BLE_ATT_VALUE_ARRAY_SIZE = X
  • CFG_BLE_NUM_GATT_ATTRIBUTES = X
  • CFG_BLE_NUM_GATT_SERVICES = X
Has anyone managed to get these values for the WB10
Shahin
ShahinAuthor
@Remy ISSALYS​ Would you be able to help with this?
Remy ISSALYS
Dec 16, 2022 7:24 PM UTC
It should work with the same value as on WB15:
  • CFG_BLE_ATT_VALUE_ARRAY_SIZE = 1290
  • CFG_BLE_NUM_GATT_ATTRIBUTES = 30
  • CFG_BLE_NUM_GATT_SERVICES = 4
Best Regards
